My PC fell of my table because my headset chord got entangled in my chair, so when I moved back the PC fell. Apart from case damage the pc seemed fine, however once I tried booting it no post screen appeared, just utter blackness. I also noticed that the lights on my mouse and keyboard did not light up. So I thought that the mobo is broken. However there was a red light on my mobo indicating that the cpu might be the issue. The light would turn on when I turned on my pc but then goes away. So what could the problem be, Cpu, mobo, gpu, or all three???
https://linustechtips.com/topic/1292522-dropped-my-pc-help/
take it apart and double check everything is plugged in and secured properly.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1292522-dropped-my-pc-help/#findComment-14381440
Yeah, take it apart, and put it together again.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1292522-dropped-my-pc-help/#findComment-14381450
^ What he says
Open the case and make sure everything is seated properly. Unscrew video card, pull it out, plug it back in...
Same for cpu cooler and cpu. unseat and reseat,   unplug cpu power cable, plug back in,  same for 24 pin connector..
https://linustechtips.com/topic/1292522-dropped-my-pc-help/#findComment-14381457
Ok so I am taking everything apart and when I took the cpu off I noticed that it has one bent pin. I also noticed in the cpu socket that it seemed as if some pin slots are like darker than other if that makes sense. Could that one bent pin be the problem?
https://linustechtips.com/topic/1292522-dropped-my-pc-help/#findComment-14381470
@Barbsxx365
Can you take a side view picture of the socket and list your specs please? The socket looks very damaged
specs
ASRock B650I Lightning WiFi
AMD Ryzen 7 7700X
KLEVV CRAS V RGB (2x16GB) 6000MT/s out of the 7200MT/s I could be running
ASUS RTX 3060 OC (12GB)
Thermalright Frozen Edge 240 RGB
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1292522-dropped-my-pc-help/#findComment-14381496
Rebending the pin back into place is super simple and shouldnt cause any harm.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1292522-dropped-my-pc-help/#findComment-14381600
Just now, Barbsxx365 said:
But will this fix the problem?
time will tell once you straighten it and put it back together. I doubt that it happened while in the socket since the socket does put some clamping force on the pins to make contact in the socket, but not a ton.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1292522-dropped-my-pc-help/#findComment-14381619
