RTX 2080 TI defect and warranty HELP
Solved by st4rway,
Hi!
I would send a email requesting a RMA and wait for their reply, it may take a while, but i'm sure they'll eventually answer.
Sending the graphics card without validation is most likely not a good idea.
Legislation in Europe requires (to some extent) RMA to be processed in 30 days after validation, warranty covers the product, not the original owner, so as long as you're still under the warranty period you should be ok.
