HI all - Thanks in advance
House A - We have Synology NAS.
House B - I want to be able to directly connect to the NAS as if I was on the server.
I've tried to set up an open vpn connection from the NAS OS Control panel but I just keep getting connection failed.
Is there any step guides - like legit step by step as I've been trying this for hours now.
https://linustechtips.com/topic/1292311-nas-help-required/
Ports/firewall probably blocked.
You want quick and dirty, use something like RDP or gotomypc or teamviewer to get into it.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1292311-nas-help-required/#findComment-14380266
You need to configure the firewall of house A to allow the webgui of the NAS ( lets say port https 443 ) and any other service your want.
VPN is not what you want, VPN is like one level higher, you need plain old NAT and port forwarding. Have a look at your router.
https://linustechtips.com/topic/1292311-nas-help-required/#findComment-14392323
