If that doesn't work then it failed -> trash
F@H
GPD Win 2
https://linustechtips.com/topic/1292215-usb-drive-read-only/#findComment-14379559
Does using disk management to try to create a new partition help? If so, I would definitely test the USB stick afterwards to see if it doesn't immediately fail with a test like H2testw.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1292215-usb-drive-read-only/#findComment-14379604
