Enough power to Cpu ?
Go to solution Solved by Tigerleon,
1 minute ago, Knallskott.Swe said:
The GPU is an Gigabyte 1070 OC 8gb, and ram is 16gb (2x8) mounted in A1 / B1- DDR4 Corsair vengeance 3200
I think you're good. You shouldn't really worry about that FPS. Kolla på andra benchmarks och se ifall de har samma FPS i det spelet.
Hi.
I just finished my rebuild of my Computer, tho im a bit worried my cpu dosent get the right amount of power to deliver
the correct FPS, (105-115 in shadow of the tomb raider)
In bios and in the Taskmanager it says the cpu is giving 4,6 ghz / core (9700K)
Would it still give that amount if it wasnt getting the right power?
https://linustechtips.com/topic/1292167-enough-power-to-cpu/
13 minutes ago, Knallskott.Swe said:
Hi.
Not much info to go on. Why would it not give enough power? Is it your PSU that is limited or what? Jag har också en 9700k förresten ;)
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1292167-enough-power-to-cpu/#findComment-14379243
1 hour ago, Knallskott.Swe said:
I really dont know why it would´t just have a feeling that it dosent. The motherboard have 8+4 power- connectors and i´ve only connected
the 8, like it says in the instruction. The Psu have 750w.
That is no worries, the 4+ are not neccessary. Although 4.6-4.7 is what it should be at and it is fine. Unless you see major stuttering there shouldn't be a problem. Also which GPU did you pair with it? RAM speed and size?
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1292167-enough-power-to-cpu/#findComment-14379426
https://linustechtips.com/topic/1292167-enough-power-to-cpu/#findComment-14379597
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1292167-enough-power-to-cpu/#findComment-14379599
