I have a problem with my new pc, it keeps restarting when i launch a games. Not all games , for example Valorant is working fine but when i try to launch Apex legends or league of legends the pc restarts it self. My specs are
- Amd ryzen 5 5600x(cpu)
- msi twin fan rtx 3060ti (gpu)
- asrock b550 phantom gaming 4 (Motherboard)
- Deepcool DA700 80+ bronze (psu)
I checked the temps and they are not high, my bios isn’t on the latest update  .
https://linustechtips.com/topic/1292145-my-pc-keep-restarting/
What is your RAM and the specs of it? CPU cooler too, though even stock cooler can handle a 5600X fine.
Yours faithfully
https://linustechtips.com/topic/1292145-my-pc-keep-restarting/#findComment-14379080
while this shouldn't really be the issue since you can run more power hungry games, that it resets by not getting enough power or something.
I kind of wonder how good that PSU is? but try to see if you can do an "simple" overclock your system, if it's crashing that might be something. else not sure.
https://linustechtips.com/topic/1292145-my-pc-keep-restarting/#findComment-14379116
Sometimes power related issues can be as simple as the PSU CPU/24PIN/PCI-E...etc cables are not seated correctly, also double check the RAM while you do this.
Does it restart if you run a CPU benchmark like cinebench r20, if it doesnt then you can eliminate CPU from the issues.
Try running 3dmark and if it doesnt restart you know its driver/software based issue.
Another common one is an overtightened heatsink or aio block on the cpu, however that usually means the PC doesnt turn on at all.
Monitor: Alienware AW2518HF CPU: 9900K @ 5.1GHz Heatsink: 2x360MM Custom Loop GPU: MSI GeForce RTX 2080 Ti GAMING X TRIO RAM: Patriot Viper Steel DDR4 2x8GB 4400Mhz Mobo: Asus Maximus XI Gene Case: Fractal Design Meshify S2 PSU: Corsair RM1000x Storage: Seagate Firecuda 510 2TB M.2, Adata XPG SX8200 PRO 256GB M.2
https://linustechtips.com/topic/1292145-my-pc-keep-restarting/#findComment-14379253
17 hours ago, Epicnezz said:
make sure your motherboard is updated with the newest bios
Hello @SHLBE,
This is something you should do first. I've run into BSODs and random shutdowns in the middle of games, on one of my systems, when the BIOS was not updated to the most recent release(although my MB was an Asus).
DeepCool Support
https://linustechtips.com/topic/1292145-my-pc-keep-restarting/#findComment-14382751
