so whenever im in microsoft teams and i turn on my microphone, they dont hear me. what could be the problem? I already tested the microphone itself, its fine.
Specifications:
MOBO: AsRock B450 PRO4
PSU: some kind of Corsair 80+ bronze
CPU: AMD Ryzen 5 3600x
GPU Radeon RX590
RAM 16 GB G.skill Ripjaws 3200mhz
Fans: Xilince and Aerocool
https://linustechtips.com/topic/1291238-plz-help/
Check audio settings and select the microphone instead of system default
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1291238-plz-help/#findComment-14372996
yes i have been in the settings, its set to  my headphones mic (the one I use)
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1291238-plz-help/#findComment-14372998
Try shut down teams. Go to windows and go to sound control paneland check if speakers and microphone (on headset) is set to default
image.png.67ad36ed1ad98ee288efa32cfc8b8dd7.pngimage.png.b59617614615aaa122fc11c5baf05b45.png
Restart pc and enter teams again
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1291238-plz-help/#findComment-14373009
yes i have done that. the headphones dont have drivers btw so it cant be that
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1291238-plz-help/#findComment-14373012
check the teams settings if the microphone/headset is selected to "standard" if you can manually select the specific microphone
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1291238-plz-help/#findComment-14373035
