My First Build, Thoughts?
Solved by Dmon,
Here is a benchmark against the two Im not buying from australia and I plan to be able to save up and replace the cards later
As a general rule of thumb I'd say always buy the single best card you can afford, rather then two cheaper cards that give slightly better performance. You won't have to deal with the problems that accompany sli/crossfire such as no/bad driver support, stuttering, more heat and more power consumption.
Just my two cents, if you're getting the 760's super cheap from overseas then I'd understand.
