Hi
I have the JBL E55BT headphones and they have been working great until recently. A moth or 2 ago, the headphones started disconnecting or would stop playing audio when opening some apps and now today the headphones arent turning on for some reason. I made sure they are fully charged but still they dont turn on. Please help
https://linustechtips.com/topic/1291087-jbl-headphones-help/
21 minutes ago, GeneralGusher said:
Hi
I don't think theres much you can do when it comes to earphones, you can try charging them overnight and try connecting them again, but other than that, a RMA is all you can do really. (This is why I love Best Buys Geek Squad Protection.)
Chicago Bears fan, Bear Down
https://linustechtips.com/topic/1291087-jbl-headphones-help/#findComment-14371947
I was also thinking of returning and getting different ones if you have any recommendations.
https://linustechtips.com/topic/1291087-jbl-headphones-help/#findComment-14372091
