Ive got some great builds on My pc guide that you could check out. a 3060ti + 5600x combo would be around your budget unless you think you'll need more/less
if you have any questions please ask
OUTDATED JAN 2021 ===========> Check out my pc building guide! might be useful tho
It's great for planning new builds, getting a reference on where to start, or seeing what you need to play what games.
It also shows what I recommend for upgrading your stuff!
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd - 970 evo plus 500gb
ssd2 - 860 qvo 1tb
mobo - asrock b450m hdv r4.0
psu - evga b5 550w bronze
https://linustechtips.com/topic/1290891-pc-config-help/#findComment-14370625
Thnx, this helped me a lot. Tank you very much.
https://linustechtips.com/topic/1290891-pc-config-help/#findComment-14372382
Apparently 5600x costs around $400 in india. So I'll recommend something like this instead...
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor (₹17964.00 @ Amazon India)
Motherboard: MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard (₹7300.00 @ Amazon India)
Memory: ADATA XPG GAMMIX D10 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (₹5999.00 @ Amazon India)
Storage: Kingston A2000 500 GB M.2-2280 NVME Solid State Drive (₹5702.00 @ Amazon India)
Video Card: Gigabyte GeForce RTX 3060 Ti 8 GB GAMING OC PRO Video Card (₹47460.20 @ Newegg India)
Case: Antec VSK10 Window MicroATX Mid Tower Case (₹4199.00 @ Amazon India)
Power Supply: Antec Earthwatts Gold Pro 750 W 80+ Gold Certified Semi-modular ATX Power Supply (₹7314.00 @ Amazon India)
Total: ₹95938.20
Generated by PCPartPicker 2021-01-08 20:38 IST+0530
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1290891-pc-config-help/#findComment-14373662
