I need help with my FPS. I recently replaced my MoBo and CPU, and I'm getting around 30-50 FPS with my GPU overclocked and the everything down to the lowest setting.
My previous setup ran an i5-7600k CPU with a MSI Z270 Pro Carbon Gaming with the same RAM and GPU with everything cranked to max in the settings and I still got around 100-115 FPS.
SO what I'm asking is, why is my FPS so low with my current more capable setup than my previous one?
Current rig:
MoBo: Asus ROG Strix Z490-E Gaming
CPU: i9-10850k
GPU: MSI RTX 2080 Gaming x Trio
RAM: 16GB @ 3200Mhz
https://linustechtips.com/topic/1290754-low-fps-help/
You shouldn't do that, especially with a 2080. Lower settings on higher end GPUs will make the game rely on the CPU more afaik. Crank it to the Max or High at least and see how that preforms.
Chicago Bears fan, Bear Down
https://linustechtips.com/topic/1290754-low-fps-help/#findComment-14369350
I tried it at max as well and still nothing better than 40 FPS
https://linustechtips.com/topic/1290754-low-fps-help/#findComment-14371154
Just now, mecodyquinn said:
Mostly all games are running really rough or low fps. The CPU utilization is around 60-70% and the GPU is at 0-1%
Game seems to be running on Integrated graphics I guess? Have you tried reinstallin the grpahics driver?
https://linustechtips.com/topic/1290754-low-fps-help/#findComment-14371198
