I'm thinking of building a PC, but I feel like I've got a bottlenecking problem on my hand.
My processor is going to be a Ryzen 5 3600, but my GPU is going to be a 3060 Ti.
I'm from Australia, so PC Partpicker Aus doesn't show a lot (nor at good prices). I found a relatively cheap 3060 Ti, and it wasn't much more expensive than the 2070 Super I found, so I jumped at the chance, but I thought I might have a bottlenecking problem. So I put the details of my would-be setup into a bottleneck checker, and it came out with a 20% bottleneck.
Should I downgrade to something like a 2060 Super, 2070 or 2070 Super and put that money towards a better processor like an i5 10600k?
https://linustechtips.com/topic/1290640-need-help-figuring-out-a-bottleneck-problem/
Bottleneck calculators aren't super accurate, in my opinion. What games are you planning to primarily play, and at what resolution? Most games are pretty GPU-bound these days, and the 3600 is still a very solid CPU.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
Does the Bottleneck checker even have a 3060ti option? As far as I know a 3070 and a 3600 doesn't even bottleneck much, and is a decent pairing, considering that a 2080 is paired with a 3600 and the calculator says GPU Bottleneck. It depends on games and res, thats why these calculators aren't always the best (and is usually ignored by others)
Chicago Bears fan, Bear Down
just ignore bottleneck calculators. it's a fine pairing. HWunboxed did an examination with an RTX 3070 and R5 3600 just recently
Primary PC:
PSU tier list
How many watts do I need?
I'm mainly going to play Rainbow Six Siege, Valorant, LoL and Minecraft, but I'll also occasionally play an open world game.
All of those are very easy to run, so you probably don't need a GPU even as powerful as a 2060 Super. You found a 3060ti at a reasonable price though so you should just keep it in case you want to play more demanding games in the future.
Also, the R5 3600 is easily able to reach 240fps in each of these games, which is the highest refresh rate I would assume you have, so don't worry.
The more I learn, the more I realise I don't actually know anything.
Recommendations: Lian Li 205m (sleek, pretty decent airflow for a non-mesh front panel and cheap), i5-10400f (Ryzen 5 3600 performance, 20% cheaper), Arctic P14 PWM fans, Logitech g305.
