Silicon Power UD70 vs P34A80 1TB. Which one is better?
They are both good drives, it depends on what you are looking for. The P34A80 is TLC while the UD70 is QLC. TLC will have higher TBW values. In terms of speed at 1TB the P34A80 would perform better being TLC, but the price for the QLC should be lower.
Once again depends on your needs if you are going to do frequent write operations go for the P34A80. If you don't care about TBW and want lots of storage for the same price go for the UD70 at 2TB; at 2TB the speeds will match the ones for the 1TB P34A80. I have bought several P34A80 and I would say 9 - 10 maintain the Phison E-12 controller, I just remember getting 1 with the Silicon Motion controller back in February last year and tbh it still performed like a beast. Personally, I would go for the P34A80 TLC at a value :)
