Budget (including currency):
$100 - $200
Country: USA
Games, programs or workloads that it will be used for: Games
Other details I have a B450 Aorus Pro WiFi motherboard and 8 gigs of RAM
I found it in the trash, and want to know what you guys think I should do. This is my first tower that I'm going to build and know nothing about building PC's. Thanks in advance for everything and your YT channel.
https://linustechtips.com/topic/1290231-need-help/
check out My pc guide its got some great budget builds. I'd find some cheap ryzen 3 or 5 cpu on ebay. I'd find another cheap computer with at least a 400w psu and steal that for the drive, case, and psu. Then chuck some cheap ssd and gpu in there (good recommendations on my guide) and bam! budget gaming pc. this is assuming ur other stuff still works...
OUTDATED JAN 2021 ===========> Check out my pc building guide! might be useful tho
It's great for planning new builds, getting a reference on where to start, or seeing what you need to play what games.
It also shows what I recommend for upgrading your stuff!
cpu - ryzen 5 3600
gpu - gtx 1070
ram - (2x8) 3200mhz
ssd - 970 evo plus 500gb
ssd2 - 860 qvo 1tb
mobo - asrock b450m hdv r4.0
psu - evga b5 550w bronze
https://linustechtips.com/topic/1290231-need-help/#findComment-14365420
If it's in the trash, there is probably a reason for it...
One of them parts (or both) may not work.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1290231-need-help/#findComment-14365428
