What CPU will age better?
17 members have voted
  1. 1. What CPU will age better?
    • 4c/8t (SMT)
    • 6c/6t (no SMT)
    • Probably doesn't make a difference
Hello everyone,
i'd like to know your "educated guess" on what CPU probably ages better. Think only about the core/thread count. Same architecture, clock speed, IPC, etc. That's one i've found hard to answer myself.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1289451-poll-what-cpu-will-age-better/
It's not going to make a difference.
If ran at stock frequency, processors have a life expectancy of 100,000 hours at load within their TDP design point.
That doesnt matter on core count either. All cores are produced close enough to all the same and binned according to its capability to the part number to achieve the life expectancy.
Sorry for the misunderstanding, but i'm not talking about the lifetime of the CPU. I'm talking about what will perform better in the long run.
My opinion:
They'll both start sucking at around the same time (now, with strong GPUs) and by the time any differences between them start to matter they'll both be too slow anyway.
SMT/HT is supposedly a 25% efficiency increase (when applications can properly use it) so it's either 6 actual cores or 5 effective cores. Ballpark.
Security shit will probably hurt the 4/8 more though.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
Ohhhh!!  I see.
Probably the 8 threads SMT while some games do scale 8 threads.
6 cores short on HT smt probably ok for most games. But I think we going to scale past 8 threads in the next few years.
Isn't 4c8t at it limits in games already? I mean even 10years ago people upgraded from 4c4t for better performance, but now we hope that it still has some headroom left.
While 6c6t isnt great either, I would rather buy that.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
There aren't many high frequency 4/8 chips to buy new today. You've got two Ryzen CPUs who's street prices negate the benefit of buying them in the first place, and locked i3's that are just lower frequency (albeit still cheap, though).
I would not recommend a 3500x or a 9600k (both $199) to buy today, which are the only (and one generation old) recent chips in the 6/6 configuration. Regarding 4/8, a $110 i3-10100F/$120 i3/10100 could be compelling, but $183+ Ryzen 3 3100 and unicorn 3300x are just stupid when you can get a Ryzen 5 3600 for $210.
Actually for the prices of all of these chips, the 6/12 i5-10400F for $160 is the best value. Otherwise pony up + camp for a 5600X.
