Bought this AIO cooler. Came in the mail and I'm pre-wiring in preparation of my build tomorrow. Does anyone have a clue as to how you are supposed to utilize the USB-2 > USB Male Head > Female > RGB USB Header Female?
I'm using the Z490-A ASUS PRIME motherboard. I'm not sure if this will be compatible or not though.
https://linustechtips.com/topic/1289394-help-with-ml360r/
Have you looked at the user manual? https://coolermaster.egnyte.com/dl/q6AT6rqK0g/?
https://linustechtips.com/topic/1289394-help-with-ml360r/#findComment-14362390
