Hey there! So... Back in 2018 i bought this computer which (i'll list the specifications below) that i wanted to be able to stream and game from the same PC. I've learned that probably wasn't the smartest choice for many reasons. I decided to follow a guide about overclocking my x7900 which works about 85% of the time but i'm really trying to make this build more stable while being able to get more FPS on games specifically Escape From Tarkov. (Which i know isn't well optimized but i would like this to run better)
I would love help with being able to increase my overclocking build i used from this video and i'll mention the my computer specs.
Here's my build.
CPU: i9-7900X
GPU: 11GB PNY Geforce GTX 1080TI
Motherboard: ASUS X299E ROG STRIX
RAM: 32GB HyperX 3000MHz
Power Supply: EVGA 1300W G2
Liquid Cooling: ORIGIN FROSTBYTE 360
Capture Card:ELGATO HD60 PRO
Currently i'm overclocked to 4.5 GHz.
The video i used in reference was and i've time stamped the exact moment where the settings are mentioned.
This was a pre-build from Origin PC which i love but still.. I'm looking for stability and as much performance as possible while being stable.
While playing Escape From Tarkov, I won't experience any issues at all.
Only with Battlefield 5 / Call of Duty Black Ops Cold War - Will the PC BSOD and mention an error about DPC_Watchdog both while just playing the game or alt tabbing.
I'm more than willing to try anything needed to make this work better so i'm all ears!
Main goal - Making this build stable w/ max performance along with hopefully no BSOD. If you need any information from me let me know!
Are you using the same voltage as Linus did in the video? When it comes to overclocking, a lot of what you're able to squeeze out is luck of the silicon lottery. Your options to increase stability are essentially:
1) Reduce your multiplier
OR
2) Increase your voltage.
Now, I'm not sure what safe voltages are for your CPU, but I know that the 1.6v in that video is crazy high compared with what I'm used to on non-X intel chips. Increasing voltage carries with it risk of permanently damaging your CPU, and also will raise your thermals.
I'd recommend looking at what's considered a "safe" voltage range for your CPU and work within that. If you're at the top of the safe range, then it's probably time to dial back the multiplier to 44.
