Front panel connectors. Look at your motherboard manual for the placement of the cables.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1287943-help/#findComment-14347879
Should be fairly obvious, they're labeled. Power switch, reset switch, power led, and hard drive led.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1287943-help/#findComment-14347885
