yes it does. from the Koolance website:
The Koolance CPU-380 sets a new standard for manufacturing quality and thermal performance. From the cold plate and flow path to the mounting hardware, every aspect of the block has been refined with unprecedented results.
It features a microfin nickel-plated copper cold plate, acetal top, and thick steel mounting bracket. Standard G 1/4 BSPP threading will accept any Koolance fitting diameter up to 19mm (3/4in) OD compression style. Please select the desired fitting type for this base model (it does not include fittings). The CPU-380I supports most boards using the following processors:
  • Intel socket LGA 2011
  • Intel socket LGA 1150
  • Intel socket LGA 1155/1156
  • Intel socket LGA 1366 (may require BLT-CPASZD12 if motherboard back plate is fixed)
  • Intel socket LGA 775
pretty simples 1155 and 1150 are the same.
