Turn on XMP in the bios
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/1286716-ram-speed-problem/#findComment-14339226
43 minutes ago, WrigglySplash said:
If you are still having issues for some reason with getting XMP to work, check out this guide on how it works and how to use it.
yea when i turned xmp on my pc wouldnt boot had to restart cmos. tried to do it manually and the ram wont go over 3066 mhz. I will check guide out.
https://linustechtips.com/topic/1286716-ram-speed-problem/#findComment-14339472
1 minute ago, YesimethanYT said:
I bought c18 3600 instead of c16 3600 is this is why?
No that shouldn't matter.
anyway for people to be able to help you better you should probably post full specs first.
-Scott Manley, 2021
https://linustechtips.com/topic/1286716-ram-speed-problem/#findComment-14339504
PC Specs:
● CPU: AMD Ryzen 5 2600X 3.6 GHz 6-Core Processor
● GPU: EVGA GeForce RTX 2060 8gb
● MOBO:MSI B450 Gaming Plus MAX ATX AM4 Motherboard
● RAM: Corsair Vengeance LPX 16GB (2 X 8GB) DDR4 3600 C18
● PSU: Thermaltake Smart 600 W 80+ Certified ATX Power Supply
● SSD: Kingston 120GB
● OS:  Windows 10
https://linustechtips.com/topic/1286716-ram-speed-problem/#findComment-14339514
you could run memtest (read description) https://www.memtest86.com
to see if the ram is actually faulty... you could also return the ram of course but then I'd get a different one, but make sure it's actually compatible with your motherboard also.
-Scott Manley, 2021
https://linustechtips.com/topic/1286716-ram-speed-problem/#findComment-14339585
