Welcome to the forum!
There are some basic troubleshooting steps that you can take when a new PC isn't booting up. Here's three easy ones to start off:
  1. Check all cables and connectors, both from the power supply and from the case.
  2. Reset the CMOS on your motherboard. There should be instructions in the manual, or there are plenty of guides online.
  3. Reseat key components (i.e. RAM, CPU, GPU, etc).
Also, would you mind sharing your system specs with us? It'll be useful if we can check your system compatibility one last time.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1285444-help/#findComment-14331629
