10 hours ago, Senzelian said:
With those two connectors alone you won't be able to control them.
I already have an argb controller for my fans which has 2 xtra argb ports. I was just wondering if its possible to wire it up that i can sync it with the rest of the fans to the motherboard.
https://linustechtips.com/topic/1285041-argb-maybe/#findComment-14330136
From what I can tell, it's a basic non-RGB led strip. Probably 12V. Easy to check if it takes 12V or 5V from molex. aRGB does nothing to it, cause it has no chip, no controller. The only control is On / Off and maybe dimming. Might be possible to wire it to 12V RGB header, not sure at all.
https://linustechtips.com/topic/1285041-argb-maybe/#findComment-14338188
