Post your full system specs. Also, if it states you're using integrated, do you have your display cable plugged into your Graphics card or Motherboard?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
1 minute ago, lukeya01 said:
@Skiiwee29 corsair lpx 8gb ram, ryzen 3 3200g and zotac geforce gtx 1060 3gb and the display cable is plugged into the motherboard
Thats why. The 3200g does have onboard graphics, but is not nearly as powerful as your 1060. You will need to plug it into the Graphics card to utilize its power.
Community Standards
"Beast Mode"
