Help with my Hardrive
Go to solution Solved by lh99,
No, also i would strongly recommend getting an ssd as a boot drive as this will be the most noticeable performance gain. Steam, Rockstar Games or other Librarys can be easily found under the new operating system for guides just google it. If you dont plan on reinstalling windows than you dont have to do anything.
https://linustechtips.com/topic/1284037-help-with-my-hardrive/#findComment-14322148
Thank you this helped strongly and thx for the advice
https://linustechtips.com/topic/1284037-help-with-my-hardrive/#findComment-14322350
