Python Requests: Error when inside Try, inside if
Solved by LewisSpring,
2 minutes ago, WereCatf said:Declare the mail - variable before the if - clauses. Even just a mail = None would suffice as a declaration and should fix the issue.
Hi there! .
I just realised the issue - It's trying to act on something that hasn't been set - since email was 0, it was not creating the "variable" to get the text from.
Thanks!
