First time building a pc need help.
Go to solution Solved by Aereldor,
Hi, welcome to the forum. Please use pcpartpicker.com
That's not a very good build for $1200. Try this instead, but keep in mind it may take some time for Ryzen 5600x and RTX 3070 stock to replenish.
If you're dead set on buying it now, then this is the best you'll get for the money-
Budget (including currency): 1200
Country: usa
Games, programs or workloads that it will be used for: video games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): wondering weather these items are good or should i be getting different parts please let me know, thanks.
Samsung SSD 860 EVO 1TB 2.5 Inch SATA III Internal SSD (MZ-76E1T...
  • #1 Best Seller in Internal Solid State Drives
  • $99.99
  • In Stock
  • Eligible for FREE Shipping & FREE Returns
  • Capacity: 1TB
Delete
1
  • Delete
  • Save for later
Compare with similar items
AMD Ryzen 5 3600 6-Core, 12-Thread Unlocked Desktop Processor with Wraith Stealth Cooler
AMD Ryzen 5 3600 6-Core, 12-Thread Unlocked Desktop Processor wi...
  • $239.99
  • In stock on January 5, 2021.
Delete
1
  • Delete
  • Save for later
ASUS Prime B550M-A WiFi AMD AM4 Zen 3 Ryzen 5000 & 3rd Gen Ryzen Micro ATX Motherboard (PCIe 4.0, WiFi 6, ECC Memory, 1Gb LAN, HDMI 2.1/D-Sub, 4K@60HZ, Addressable Gen 2 RGB Header and Aura Sync)
ASUS Prime B550M-A WiFi AMD AM4 Zen 3 Ryzen 5000 & 3rd Gen Ryzen...
  • $129.99
  • In stock on December 27, 2020.
Delete
1
  • Delete
  • Save for later
EVGA 110-BQ-0600-K1 600 BQ, 80+ Bronze 600W, Semi Modular, FDB Fan, 3 Year Warranty, Power Supply
EVGA 110-BQ-0600-K1 600 BQ, 80+ Bronze 600W, Semi Modular, FDB F...
  • $79.95
  • In stock on December 29, 2020.
  • Size: 600W
  • Style: BQ
  • Pattern Name: Power Supply
Delete
1
  • Delete
  • Save for later
TEAMGROUP T-Force Delta RGB DDR4 32GB (2x16GB) 3200MHz (PC4-25600) CL16 Desktop Memory Module Ram TF3D432G3200HC16CDC01 - Black
TEAMGROUP T-Force Delta RGB DDR4 32GB (2x16GB) 3200MHz (PC4-2560...
  • $139.99
  • In Stock
  • Capacity: 32GB (16GBx2) - 3200MHz C16-18-18-38
  • Color: Black
Delete
1
  • Delete
  • Save for later
NZXT H510 - CA-H510B-B1 - Compact ATX Mid-Tower PC Gaming Case - Front I/O USB Type-C Port - Tempered Glass Side Panel - Cable Management System - Water-Cooling Ready - Black
NZXT H510 - CA-H510B-B1 - Compact ATX Mid-Tower PC Gaming Case -...
MSI GeForce GTX 1660 SUPER DirectX 12 GTX 1660 SUPER GAMING X 6GB 192-Bit GDDR6 PCI Express 3.0 x16 HDCP Ready Video Card
https://linustechtips.com/topic/1283786-first-time-building-a-pc-need-help/
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
I agree with @Aereldorlist except I would go with a better power supply as it is only Tier D on the ltt tier list. I would go with something like the corsair cx/cxm/txm 650w. It is definitely worth the extra money for more reliability.
