1 minute ago, Grigor said:
Hello guys recently i add nvme to my system when i copy some file it goes up to 600bytes/s then sometimes drop to 0 then go again fast and stop for a while again is that normal ?
No, that's not normal transfer speeds for an NVMe drive.
What are you copying the files from? A USB flash drive? HDD? Downloading from the internet? The transfer speed will be limited by whatever it is reading the files from.
https://linustechtips.com/topic/1283354-nvme-problem/#findComment-14317578
i move 30gb from D partition to C its only from the nvme itself but i do transfer from nvme to flash drive and again drop to 0 sometimes then go up is that normal...
https://linustechtips.com/topic/1283354-nvme-problem/#findComment-14317581
