Motherboard: Gigabyte A520I AC
RAM: TEAMGROUP Elite DDR4 64GB Kit (2 x 32GB) 3200MHz (PC4-25600) CL22 Unbuffered
Storage: Silicon Power 1TB - NVMe M.2 PCIe Gen3x4 2280 TLC SSD
Case: Fractal Design Define Nano S
Graphics Card: Sapphire Pulse Radeon RX 5500 XT
Processor: Ryzen 9 3900 X using stock AMD cooler
PSU: EVGA Supernova 550 GM (550 W) 80 Plus Gold Fully Modular
He plans on connecting 4 27" monitors to have as many windows open and visible as possible.
Hello! I have the above listed parts for a PC that I am going to build for my friend. I intend to start building it in a few days, however, I realized that even though I have all the parts, what I don't know is how to wire them all together. As this is my first time building a PC, I think instead of just going in blind and trying to "wing it", it's probably better for me to find some guide or helpful video to figure how to wire all of the parts to each other and to the motherboard. Is there a Pc parts wiring video or guide that you would recommend I use?
Thank you
https://linustechtips.com/topic/1283223-wiring-help/
All the cables on your power supply will be listed as to where they go
It's fairly user friendly
https://linustechtips.com/topic/1283223-wiring-help/#findComment-14316738
