Using Ryzen DRAM Calculator 1.7.3
Go to solution Solved by Guest,
9 minutes ago, RogueBet4 said:
Yes.
So u mean I need to select Hynix CJR/DJR?
Correct.
These are Hynix CJR or C-die.
Rather than higher frequencies, they are better known for tight timings at lower frequencies.
Since the kit is 2667mhz at 1.20v, you could see how they fair with up to 1.35v.
Might get closer to 2933mhz at the XMP timings, OR, can tweak the XMP frequency to tighter timings which should help reduce that latency.
the problem that there is no C-die at the dram calculator
  • 2 weeks later...
