Need help reducing cpu temperatures.
Go to solution Solved by Moonzy,
2 minutes ago, Jaaay said:
These are the parts surrounding it,
i cant really tell but it looks plugged in
ive also noticed a little of moisture ontop of the gpu, it this concerning as the pipes are right above it, could it possibly leaking right now?
yes, i believe it is leaking due to the pressure buildup inside your AIO that didn't receive proper cooling and the water are just near boiling
replace it asap, if you want something simple, an air cooler will do
After wondering why my pc was feeling very sluggish while gaming my friend asked me to show him my temperatures and I noticed that it was maxed out at 100 degrees.
It turns out the cooler for my cpu didn't have a fan installed.
I recently went out to buy one and while it seems to helped a bit my cpu is still struggling to stay cooler
The image i've attached is my current idle status, I've had my pc running for maybe 15-20 mins without any games or other intensive programs running.
What can I do to fix this?
The program being using is speccy if anyone knows a more reliable program i'd love to know.
https://linustechtips.com/topic/1282445-need-help-reducing-cpu-temperatures/
do you know the model of the cooler?
or a photo would be great
HWinfo is great, from what i heard
i personally use msi afterburner, but that's more for gpu
hashire sori yoo...
welcome to the forum, remember to quote or mention when replying to someone so they'll get a notification
@Moonzy
-sigh- feeling like I'm being too negative lately
hashire sori yoo...
Is this sufficient, if not how do i find the exact model, also i believe its meant to be lit up, i dont know if its an indication of it not working or not,
does the pump have any cables connected to the motherboard or anywhere else?
if yes, can i get a photo of that?
and if yes, is the pump vibrating when you touch it?
kaze no you ni
I have a i7 8700k on a AORUS Ultra. I keep it cool with a be quite Dark Rock Pro 4.
For water cooling I would not use less than a 280mm AIO for overclocking and a 240mm for stock.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
kaze no you ni
im sorry but what part exactly is the pump sorry im not to used to compuer parts.
These are the parts surrounding it, ive also noticed a little of moisture ontop of the gpu, it this concerning as the pipes are right above it, could it possibly leaking right now?
This is currently how the cooler is installed, i searched up the fans you mentioned, would i be able to fit them here?
Someone reccomendes a 280mm in an above comment. Ive posted a picture of the side of my case. Would it be able to fit there?
from your photos, i cant tell
280 normally goes on top or in the front
but you'll have to check the case's product page for confirmation if it supports it
Your cooler looks like it is a 120mm(single fan) AIO. An i7 8700k need a more cooling.
240mm and 280mm have 2 fans.
Here is what a 240mm looks like. https://www.newegg.com/corsair-icue-h100i-rgb-pro-xt-liquid-cooling-system/p/N82E16835181190
It would either have to go at the top of the case or in the front of the case.
This is what I use on my i7 8700k. https://www.newegg.com/be-quiet-dark-rock-pro-4-bk022/p/13C-001F-00027?Description=be quite dark rock pro 4&cm_re=be_quite dark rock pro 4-_-9SIA68V6YA3005-_-Product&quicklink=true
