HELP! WEIRD SCREEN PROBLEM
Solved by Analog,
3 minutes ago, modestep15 said:Yeah, there was a recent driver update when Cyberpunk released and another one a couple of days ago
Ok, in that case the easiest thing to do would be uninstall the existing drivers with Display Driver Uninstaller , disable the interenet connection so that Windows cannot reinstall automatically and after that do a clean install of the latest version directly from the manufacturer's website. Do a restart and see how it is. Don't forget to download the latest drivers before removing the existing ones and disable internet connectivity.
