Budget (including currency): entry level
Country: UK
Games, programs or workloads that it will be used for:
GeForce GTX 1650 Super graphics cardsold out everywhere!
Any recommended alternatives?
Entry level budget unfortunately.
Think I'm getting i3 9100f, Gigabyte Z390 D ATX LGA1151 Motherboard, Corsair Vengeance LPX 2x 8GB DDR4 3600, 1TB HD, 256GB SSD
Ordering everything today
Can anyone help?
https://linustechtips.com/topic/1281872-urgent-help-needed-first-pc-build/
Country: UK
Can anyone help?
Don't do it. Wait for the 1650 super to be in stock. If you HAD to order today, this RX 570 could work, it is quite expensive however.
The 1 TB HDD and 256 GB SSD is still fine
geometry is hard
b550 > x570
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
2 minutes ago, MTKT said:
Thats just a "mini" version of the 1650 super. It will have the exact same performance as all other 1650 supers.
geometry is hard
b550 > x570
Thanks for the help.
@Downkey @HelpfulTechWizard if I get the components you've listed, do i need anything else?
presumably an operating system (planning Windows 10 Home 64 bit),
monitor, keyboard, mouse
speakers / headphones
- do i need to get any parts so that speakers/ headphones / wifi work?
I'm actually trying to get the components for my son to build, so sorry for ignorance on all this.
That all depends
Does your son have a keyboard, mouse, and headphones?
Does he use wifi?
Also don't buy a Windows 10 key at MSRP. Huge waste of money, especially for your budget
geometry is hard
b550 > x570
Yes, keyboard, mouse, headphones should be sorted.
We will need to use some sort of internet & likely computer will be upstairs, WIFI box downstairs.
What do you mean 'at MSRP'?  I thought it needed some kind of operating system? (I might use it for work, as well as son's gaming, but have a Microsoft 365 through work we can use)
you can buy Windows on ebay for like $5
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
Ah - didn't realise that.  Is it an immediate download @wall03 and does it work just as well?  If so, I might leave that up to my son to sort & save myself £100!!!
you can download it for free at Microsoft's website, ebay provides an activation code needed to use the computer to it's full potential
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
So how much worse will a computer with
Asus Prime H310-plus R2.0 & GTX 1650 (not super) & only 256GB SSD not 500GB (+1TB HDD)
be compared to
Gigabyte Z390D & 1650 Super & 500GB SSD (+1TB HDD)?
I know it's entry level, but they are both way out of my original budget, so i do want there to be some future proofing involved.  can't afford to upgrade within the next year or two!
Ok - that 1650 super no longer there.
What is the 'next best thing' & how much worse is it?
I'd rather have all the parts so that son can start building on christmas day, but if it is a huge jump down for not much less money, then I might consider leaving the graphics card & putting an 'i owe you' in ....?
