Need help to active the full refresh rate
FinOxy
Go to solution Solved by FinOxy,
Oh.
I found it
The monitors I need help with
AOC 24G2U
Radeon Rx5700xt
Where is this setting
Settings > System > Display (Win+R, enter ms-settings:display in Run), Advanced display settings, Refresh rate.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
it does not open the
Only thing that it brings up is the graphics card settings/properties
4 minutes ago, PorkishPig said:
Settings > System > Display (Win+R, enter ms-settings:display in Run), Advanced display settings, Refresh Rate.
Oh, you're using an older build of WIndows 10. The option you're looking for should be in the Monitor tab of that window.
Desktop
Homelab
