HELP NEEDED FOR UPGRADE!
Go to solution Solved by Downkey,
1 minute ago, ashd2016 said:
I know a store near my house they have them in stock
If it's for under 35K RS (460USD) then you may want too do that, as they are impossible to find rn. Your psu could use an upgrade aswell.
I need help!
Current build:
  • i5-7600k
  • GTX 1060 6gb
  • Samsung evo 970
  • 16gb single channel ddr4 2400 mhz (will UPgrade to dual channel)
  • 1 tb  seagate hdd
  • 500w cooler master 80+ psu
  • Cooler master k480 mid tower case
I can feel my pc is getting dated as many games get frame drops and my current build is not really suitable for streaming I hardly get 40fps in  Apex Legends while  streaming  at 720p, need help for an upgrade path which fits my budget. Will be  Mainly used for streaming on YouTube and content creation tasks such as editing photos and videos.
Budget (including currency): ₹40,000-50,000
Country: India
Games, programs or workloads that it will be used for:
  • mostly games included in xbox game pass and ea access like battlefield 5,star wars, apex legends and  occasionally csgo and valorant
  • I want to stream Youtube/twitch
  • edit 4k footage shot on Sony a7III
https://linustechtips.com/topic/1279899-help-needed-for-upgrade/
Save the rest of your money for a better CPU down the line.
geometry is hard
b550 > x570
RTX 3060ti is avalable at around 35k-40k in India while RX 5600 XT is costing 28K should I just get the 3060ti? will it cause a significant cpu bottle neck?
Those 3060tis are being scalped. How long are you willing to wait?
geometry is hard
b550 > x570
geometry is hard
b550 > x570
Yeah GPU + PSU upgrade sounds good But can My 7600k( 4 threaded ) handle AAA games for atleast the next 1 year?
The 7600k is only 4c/4t, but if you play on higher settings (Which you can def do with a 3060ti) you should be okay, although some games like RDR2 will have a bit of trouble running
geometry is hard
b550 > x570
apparently I have a CPU bottle neck https://www.cpuagent.com/build-compare/intel-core-i5-7600k-vs-intel-core-i9-10900k/summary/nvidia-geforce-gtx-1060-vs-nvidia-geforce-gtx-1060?res=1-vs-1&quality=ultra-vs-ultra&ram=16-vs-32&ramspeed=2400-vs-3800
2 hours ago, ashd2016 said:
Those sites are complete BS. There may be small bottleneck but it won’t be extreme.
geometry is hard
b550 > x570
SMPS GIGABYTE 700W (GP-B700H)
https://www.vishalperipherals.in/index.php?route=product/product&path=62&product_id=2379
this PSU any good?
this PSU any good?
It’s fine, but it’s not great. I’d go with a better 550 - 650w unit.
geometry is hard
b550 > x570
