Issues with my gpu HELP !!!
Go to solution Solved by Radium_Angel,
12 minutes ago, DaviCan said:
XMP enabled
Turn that off.
I see more issues associated with XMP than virtually everything else combined on this forum.
If you give me some time, I'll analyze the crash dumps and see what's going on
Hey everyone, I'm new to this forum and I wanted to ask for all the help possible because I'm desperate.
It's been a while since I'm having a lot of issues with my Graphics Card.
While playing games I experience a lot of crashes and not that rarely BSOD.
My hardware:
GPU - MSI RTX 2060 Gaming Z (factory overclocked)
CPU - Ryzen 5 3600 (not overclocked, stock cooler)
RAM - Corsair Vengeance DDR4 2x8 GB 3000Mhz (XMP enabled)
MOBO - Asus Prime B450M-K
SSD - WD Blue M.2 SATA 1TB
PSU - Sharkoon WPM Gold Zero 550W
OS - Windows 10 Pro (Version 20H2 Build 19042.685)
Troubleshooting i tried:
- Update GPU Drivers from GeForce Expereince
- Update computer drivers from Windows Update
- Completely delete and fresh install GPU drivers with DDU
- Completely delete and fresh install every Microsoft Visual C++
- Update to latest DirectX
- Tried to change both TdrLevel and TdrDelay
- Checked Debug Mode in Nvidia Control Panel before starting the game
- Killed every unnecessary process in background
- Phisically remove and reinstalled the GPU
NONE OF THE ABOVE WORKED
I attached some crash infos, the DxDiag file and all the windows crash dump files.
Since it was too big, I uploaded here ( WeTransfer: https://we.tl/t-LKiTL5cXY9 ) the MSI afterburner log file (check the 8th of november 2020 16:39:00 for example)
If anyone wants or knows how to help me pls answer
Thx in advance
DxDiag.txt 110620-7437-01.dmp 111020-7453-01.dmp 111520-6421-01.dmp 121020-6265-01.dmp 121020-6453-01.dmp
https://linustechtips.com/topic/1279895-issues-with-my-gpu-help/
XMP enabled
Turn that off.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
I'm seeing a ton of code corruption in the crash files, most likely related to faulty RAM, or the XMP screwing things up. SO yeah, turn off XMP, see how it behaves.
Thx a lot. I just tried the auto mode insted of the xmp and now cyberpunk runs smooth as butter. Before it was crashing every 2/3 minutes.
I would have never thought that the fault for all of this was the RAM.
Will it affect the performance of my CPU? I know that the higher the ram freq is the better amd cpus perform. Now it is set to 2133Mhz.
You will lose a few FPS with XMP off, but you gain stability and I feel that's far more important.
Ok, thanks a lot again.
I was having this issue since july and you resolved it in like 30 minuts ahah
