help cooling oc 3800x
Hey,
I am building a pc for a friend.
The specs are:
ram:patriot viper blackout 32gb cl16 3200mhz)
ssd: samsung evo plus 1tb nvme
case: coolermaster nr600 with odd bay for blu ray disc drive
mb: msi b550 a pro (still cheap but good b550 mb)
cpu:ryzen 7 3800x
gpu: ZOTAC Gaming GEFORCE RTX 3060 Ti Twin Edge OC
Psu: corsair tx 750m if its enough for oc(some confirmation maybe?)
Now the cpu cooler:
Would be the NH u 12s enough or what cooler should I go with?
The 3800x will be overclocked with 1usmus clocktuner for ryzen about which Linus did a video.
Like would be a dark rock 4(non pro) enough? (would also appreciate some help regarding ram clearance for the dark rock 4)
I dont know many good coolers.
The nh u 14s would be the next I know, but the case has 166mm clearance and the 14s ist just 1mm short from max. Would this work? How reliable are those numbers?
Thanks in advance for the help
Update:
Going to get a ARO-M14 based on @WoodenMarkers suggestion in the Cooler Tier List Thread.
