Budget (including currency): 60
Country: United States
I want to upgrade my Ram but I'm not sure what I should go for, I currently have 2 x 4 gb ddr4-3200 from Ripjaws
I currently have two choices I've been looking at.
Ripjaws(2 x 4 gb) ddr4-3200, $44
https://pcpartpicker.com/product/m8Jkcf/gskill-memory-f43200c16d8gvrb
ADATA xpg z1 (2 x 8 gb) ddr4-3000, $55
https://pcpartpicker.com/product/KmfhP6/adata-xpg-z1-16-gb-2-x-8-gb-ddr4-3000-memory-ax4u300038g16-dsz1
Im still new to PC's building so I'm not sure what I should get
Also I would appreciate any other better RAM recommendations.
https://linustechtips.com/topic/1279690-ram-help/
3 hours ago, Castro40 said:
So what your saying is to go for the Gskills (2 x 4 gb), I appreciate the help
I was not suggesting a particular kit.
You could get the 2x8GB kit and simply pull the existing kit. Or you should be able to use both for 24GB.
https://linustechtips.com/topic/1279690-ram-help/#findComment-14291617
