I have the D5 X-Res Reservoir-Pump-Combo Unit (http://www.ekwb.com/shop/reservoirs-and-acc/res-pump-combo/ek-d5/ek-d5-vario-x-res-140-incl-pump.html). I really like the looks of it and I think that is the only thing that really matters when comparing reservoirs and pump tops :D .
https://linustechtips.com/topic/127969-best-d5-pump-top/#findComment-1702630
Well, pump tops are mostly for aesthetics and possibly give you more in/out ports... Just get the best looking one.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/127969-best-d5-pump-top/#findComment-1711444
