Budget (including currency): N/A
Country: Greece
Games, programs or workloads that it will be used for: Cyberpunk 2077, LoL, Valhalla, Future Proof too
Other details current pc: Rtx 2060 /// ryzen 5 3600x /// 16G 3000hz /// getting 850w soon for upcoming build
Hey there everybody, my first post here!
Alright here is my question so basically I’ve been busting my head trying to figure out which gpu I should go for I’m between 3070/3080 and I just seem to have the knowledge to make such a guess, I’m only playing on a 1080p monitor and that won’t change for now at least. I’ve also thought of going 3070 and getting a 5600. Any new suggestions would also be great but I know you guys here are pros so I wanna hear your opinions!
https://linustechtips.com/topic/1279669-help/
A 3070 would be plenty for 1080p
Even a 3060ti
As for your CPU, I don't really see a point in upgrading unless it's limiting you in some way?
Tbh, upgrade only when you feel like your PC isn't enough, not when new stuffs are out
2060 is still plenty for 1080p gameplay
But if you do want to upgrade, find out what's limiting your games now, then upgrade that part of you're unhappy with the performance
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1279669-help/#findComment-14291069
Both cards are too much for 1080p, even the 3060 ti would be overkill
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1279669-help/#findComment-14291097
