Have you tried applying XMP in BIOS? If not, do that. If you have already, check what voltage the RAM is running at (it should be listed under DRAM voltage). If it's below 1.35V, increase it to that.
Have you tested both sticks of RAM individually to see if one of them is faulty?
I would suggest running the Windows Memory Diagnostic tool, but you can't really do that if you can't boot into Windows.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
yes i have tested them individually and both of them are not faulty but when i but when i use both it crashes and there is no option in my motherboard for xmp profile.btw my ram doesn't have a heatsink, ram:https://www.amazon.in/gp/product/B07GMRJTS9/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1
Okay, if it's not letting you apply XMP, then the RAM is likely running at settings that are causing instability when you try to use dual channel. I would go into BIOS and manually set the DRAM voltage to 1.35V, and the DRAM frequency to 2666 mhz. See if that fixes the issue.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
1 minute ago, ragnarok0273 said:
Which motherboard?
Posting another thread before....
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
will it be safe if i bump up the volts the ram doesn't have a heatsink
Yeah you should be fine. Most all RAM is supposed to run at 1.35V anyway, and odds are your motherboard is giving it less power than it needs, which would be what's causing the PC to crash.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
my ram is running at 1.2v so i should bump it up to 1.35v?
Yes, do that and see if it fixes the problem. You can also bump the RAM frequency up to 2666 mhz while you're at it if it's defaulted to something lower.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
there is a problem when i was trying to change the voltage i changed it from auto to manual but it doesn't allow me to change it it give me these options: standard time control,advanced time control,CAD bus drive strength and data bus configuration. what should i do?
I'm honestly not sure. Different motherboard BIOS menus look and function differently. Could you take a picture to show exactly what it's showing?
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
