help pls
Go to solution Solved by boggy77,
so the 10400f can draw a max of 140W under full stress test
the 5700xt can spike up to 250W again under stress test if you overclock it
the rest of the system doesn't draw more than 100w, most likely closer to 50w.
so in total, you're looking at a max power consumption of 500W, if you overclock the gpu and cpu (limited overclocking ability) and if you run prime 95 and furmark at the same time (not recommended).
during gaming, it will draw closer to 400w.
so the 550 txm will be fine
okay so i’m very new to pc building and was recommended a 550w tx550m gold certified psu, this is to go along side my radeon 5700xt gaming x and my intel i5 10400f along with the mobo etc. when the gpu came it said “600w minimum needed” and i panicked and asked people, looked on google etc and it’s very mixed, some people are saying 550 is fine and others are saying get a 600-750w psu. so my question is what do i need.
https://linustechtips.com/topic/1279411-help-pls/
i already posted this but it was in the wrong area of the forum.
i have a radeon 5700xt gaming x gpu and a 10400f i5 cpu, i was told 550w was fine but then the box comes with me gpu and it says 600w is needed, i’m stuck on what to do and i’m in need of help, i’m a massive pc building noob lol.
https://linustechtips.com/topic/1279411-help-pls/#findComment-14289044
System
  • CPU
    AMD Ryzen 5 5600x
  • Motherboard
    MSI MAG x570 Tomahawk Wifi
  • RAM
    64GB - Kingston DDR4-2666 16gb x4
  • GPU
    Aorus RX5700XT
  • Case
    Corsair Crystal 460x
  • Storage
    WD Blue SSD 500GB
    Seagate Barracuda 4TB
    Seagate Barracude 1TB
  • PSU
    CoolerMaster MWE White 550W
  • Display(s)
    (3) Nvision Ip24v1
    i jsut copy pasted my system specs from my profile.
    im using a 550W psu and have no problems whatsoever
There is no such thing as a bad PC, there are only BETTER PCs
https://linustechtips.com/topic/1279411-help-pls/#findComment-14289057
2 minutes ago, Zenedge said:
System
  • CPU
    AMD Ryzen 5 5600x
  • Motherboard
  • RAM
  • GPU
    Aorus RX5700XT
  • Case
  • Storage
    WD Blue SSD 500GB
  • PSU
  • Display(s)
    (3) Nvision Ip24v1
i’m in the pcmr discord and everyone’s saying i should get a 650 because 550 would probably just shut my pc off on my desktop so i’m really scared, like if i genuinely need to i’ll return my psu today and get a 650
https://linustechtips.com/topic/1279411-help-pls/#findComment-14289067
if it will make u feel better. go get a 650W. but ive been using my pc for around 2 weeks. and its never shut off even once
https://linustechtips.com/topic/1279411-help-pls/#findComment-14289071
It's fine the system consumes 450w at most. The recommended psu was up until this gen (the rx6800 and rtx3000) always an overestimation so even people with crap psu's could possibly be fine. So don't worry. If a GOOD QUALITY 650w is barely more sure why not get it more upgrade room then but if it's a lot more then don't
https://linustechtips.com/topic/1279411-help-pls/#findComment-14289093
sorry to be annoying but like, are you sure it’ll be fine, i’d prefer not to upgrade if i genuinely do not need to but if i actually need to because it’s going to affect my pc then i will
https://linustechtips.com/topic/1279411-help-pls/#findComment-14289105
https://linustechtips.com/topic/1279411-help-pls/#findComment-14289166
2 hours ago, ukiyyo said:
600w minimum needed
That is to cover the situation where you pair the 5700xt with an overclocked 10900k and a low quality power supply. The 10400f draws half the power of the 10900k and the corsair txm is very good quality and can handle high transient loads just fine.
https://linustechtips.com/topic/1279411-help-pls/#findComment-14289448
