so basically i have this pc i built my self, Ryzen 7 3700x and a asrock challenger Rx 5700xt, when I play games like cyberpunk right now and war Thunder i get a high fps but it's so freaking choppy when I play(nvm I fixed it i had to turn on Vysnc), i have 144hz freesync monitors, i also have 32 gb 3200 mhz ram with a super good psu and airflow in my case, it's also all dust free(i clean it a lot) but the main reason I need help is why my temps reach 102 degrees Celsius and chill there forever, it scares me bro and I have my gpu fans on 100, its loud and still getting hot, and supposedly the max gpu temp is 80 c while I reach 100 c,
https://linustechtips.com/topic/1279364-helppp-high-temps/
We need more info about the build. Specs. Maybe a pic of the PC with open side panel. Welcome to the forums, my friend. :)
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288780
I have the same problem with my 5700XT asus strix. At idle normal, when gamign near 100c without lowering voltage and power limit. Sad really.
Anyways take the sidepanel off and see the results. My results were the same sicne i have a high airflow case anyway. Will soon change the thermalpaste and see if the temps drop even a little bit.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288791
Those cards have unrealistically high boost clock targets ootb.
You need to apply a decent undervolt and underclock. You'll get same if not better performance and lower temps.
A decent start would be 1950mhz clock and 1050mV undervolt
There are many guides, here's a random one
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288821
44 minutes ago, DoctorNick said:
Welcome
All i know of the specs is:
Ryzen 7 3700x (base clock)
Asrock Challenger Rx 5700xt
32 gb 3200mhz ram
850 watt fully modular psu
Crucial m.2 ssd
I forgot motherboard but it's supposedly really good
Monitors:
3 curved Samsung gaming monitors
1080p
144hz
Amd FreeSync
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288835
Makes me feel better knowing im not the only one with 100 degree temps
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288836
Alright thanks ima look into it
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288838
Gamers nexus did a roundup on best 5700XT.
They have among all, charts with temperatures aswell and it varies between models. Also it might be a bad contact between the cooler and the gpu die. Id try to return it or get replaced, 100°C is just too high.
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288850
Friend has a reference 5700xt and a Fractal Meshify, we managed a pretty nice undervolt without losing performance and set up an aggressive fan curve. It also helps that he just stuck fans everywhere haha.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288992
Well it shoudl be under 70C stock. it runs 98C stock. Well i managed to run this gpu at 1850mhz with 1.075V with -10% power. Keeps under 90C.
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14288997
I bought my Saphire Pulse OC 5700XT based on GN's roundup. I had to buy a better airflow case, undervolt and use liquid metal to keep it the 70s under load
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14289458
I'd take it apart and repaste it before I sent it back. Some Kryonaut should bring it down a few degrees
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14289464
Any decent paste would do if hes ready to take it apart, Ive personally put arctic mx-4 on my rx 480 and it worked absolutely fine, or if he can, unless the warranty void sticker is on then its better sending it back first.
And it can more likely be bad contact rather than paste, its a new card the paste cant be that bad.
Also it could be just one among many that came out badly assembled or who knows.
https://linustechtips.com/topic/1279364-helppp-high-temps/#findComment-14289707
