Budget : ~$3000 AUD
Country: Australia
Used for: Games (Assassins Creed Valhalla, GTA V and Watch Dogs Legion), light CAD (Solidworks), and Adobe Suite CC (Illustrator and Premier Pro).
Other details: First time building a PC. Wanted to get into 4K gaming. Ideally the system is some what future proof. Whilst looks are not the number one priority I wouldn't mind spending a little on RGB lights. Low noise also ideal.
Current Specs Considered:
CPU - AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor
CPU Cooler - Corsair H100i RGB Platinum 75 CFM Liquid CPU Cooler
Motherboard - MSI MAG B550 Tomahawk ATX AM4 Motherboard
Memory - Corsair Vengeance RBG Pro 16GB (2 x 8GB) DDR4-3600 CL18 Memory
Storage - Kingston A2000 1TB NVME and WD Blue 1TB 2.5" SSD
Video Card - MSI Radeon RX 6800 XT 16GB RDNA 2
Case - Corsair 275R Airflow ATX Mid Tower Case
Power Supply - Corsair RM (2019) 650W 80+ Gold Fully Modular ATX Power Supply
Is this a good combination of part? Is it suited for what I would use it for?
I don't know 100% what I am doing, so any feedback would be appreciated. :)
https://linustechtips.com/topic/1279313-first-build-advice/
This would work, but there should a CL16 version of the ram, it would be faster, Other than that, I hope it all turns out good!
specs
ASRock B650I Lightning WiFi
AMD Ryzen 7 7700X
KLEVV CRAS V RGB (2x16GB) 6000MT/s out of the 7200MT/s I could be running
ASUS RTX 3060 OC (12GB)
Thermalright Frozen Edge 240 RGB
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1279313-first-build-advice/#findComment-14288514
Everywhere I looked only stock the CL18 version. Is it worth going for a 3200MHz Cl16 instead?
https://linustechtips.com/topic/1279313-first-build-advice/#findComment-14288595
In USD, how much are you spending on the RAM? I might have an option for 3600MHz C16 memory...
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1279313-first-build-advice/#findComment-14288608
Give me like 15 more minutes to whip up the perfect RAM kit from my butt...
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1279313-first-build-advice/#findComment-14288617
The best advice for a first build is not to blow 3 grand on your first ever computer lol
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1279313-first-build-advice/#findComment-14288621
Theres white and black which one u want
Relateable
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1279313-first-build-advice/#findComment-14288625
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1279313-first-build-advice/#findComment-14288634
lot of rgb:
without rgb:
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1279313-first-build-advice/#findComment-14288702
