Budget (including currency):  go nuts this is more of a goal work to not for now
Country:  united states
Games, programs or workloads that it will be used for:  abelton live and adobe apps
Other details (existing parts lists, whethare needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): yes i just want something to look for in the future/ what audio editing needs from a computer
https://linustechtips.com/topic/1279220-audio-pc/
CPU: Ryzen Threadripper 5999X (128C, 256T 3GHz-4.1GHz sTRX5)
CPU Cooler: Custom water cooling because the TR 5990X has a TDP of 500W
Motherboard: Asus Zenith III Extreme (still supports DDR4, don't worry)
Memory: 2x Corsair Vengeance RGB Pro 128GB (4x32GB) DDR4-4000 CL18
Graphics Cards: 2x RTX 3090 FE + RTX 3090 SLI bridge
Storage: 5x Samsung 980 Pro 1TB
Case: In Win 509 Medieval Metal BSMods
Power Supply: EVGA SuperNOVA 2000G+ 2000W PSU
OS: Windows 10 Pro HAV-00059
In case this PSU isn't enough, get a second 2000G+ and dedicate it just to the GPUs. Don't worry, the Zenith III Extreme has 2 24-pin connectors for two power supplies.
Supply your own peripherals.
elephants
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14287988
elephants
that is a great looking case
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288005
elephants
Huh, this would actually work fairly well lol.
Ableton tends to enjoy lots of fast CPU cores, so the CPU fits well. If it was slower clocks, then maybe not.
Obviously the GPU horsepower is not needed at all, but why not?
The build I would obviously use:
PCPartPicker Part List: https://uk.pcpartpicker.com/list/XsGzF8
CPU: Intel Celeron G5900 3.4 GHz Dual-Core Processor  (£40.22 @ CCL Computers)
CPU Cooler: Corsair H100i v2 70.69 CFM Liquid CPU Cooler  (£367.83 @ Amazon UK)
Thermal Compound: Prolimatech PK-Zero 300 g Thermal Paste  (£116.83 @ Amazon UK)
Motherboard: Gigabyte Z490 AORUS XTREME WATERFORCE EATX LGA1200 Motherboard  (£1209.99 @ AWD-IT)
Memory: Corsair Vengeance RGB Pro 128 GB (4 x 32 GB) DDR4-4000 CL18 Memory  (£1247.35 @ Amazon UK)
Storage: OCZ Z-Drive R4 CM84 1.2 TB PCI-E Solid State Drive  (£4782.54 @ Amazon UK)
Storage: Western Digital Gold 18 TB 3.5" 7200RPM Internal Hard Drive  (£473.16 @ Senetic)
Video Card: PNY Quadro GV100 32 GB Video Card (2-Way SLI)  (£10299.98 @ CCL Computers)
Case: Lian Li PC-O8X ATX Mid Tower Case  (£618.21 @ Amazon UK)
Power Supply: LEPA MaxBron 1000 W 80+ Bronze Certified Semi-modular ATX Power Supply  (£104.18 @ Amazon UK)
Operating System: Microsoft Windows 7 Professional Full 32/64-bit  (£449.99 @ Amazon UK)
Case Fan: Thermaltake Riing Quad 12 RGB Radiator TT Premium Edition 40.9 CFM 120 mm Fans 3-Pack  (£183.50 @ Newegg UK)
Keyboard: Microsoft ANB-00006 Wired Slim Keyboard  (£9.96 @ Currys PC World Business)
Mouse: V7 Full size USB Optical Mouse Wired Optical Mouse  (£2.46 @ Amazon UK)
Total: £33356.14
Generated by PCPartPicker 2020-12-10 02:06 GMT+0000
Don't you dare question the CPU, peripherals, OS or PSU choice.
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288023
Total: £33356.14
Why are you using a Celeron, Windows 7 Pro, and a bomb hiding in a PSU shell?
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288025
is that a pc or thermal compound and hard drives?
Total: £33356.14
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288030
All the budget went to fans, HDD's, GPU's and the motherboard.
You know, the things that matter.
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288031
In all seriousness OP, the PC on my profile is excellent for audio work. I make a living from mixing/mastering, and use this PC daily for everything. It's GPU and CPU is last gen now, but still works a treat.
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288032
You forgot the three optical drives:
The CD/DVD+/-RW/RAM) LightScribe drive
The Blu-Ray drive
The HD-DVD drive
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288033
The Blu-Ray drive
The HD-DVD drive
PCPP didn't have optical drives :(
I made up for it by using 900g of thermal paste though.
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288035
Total: £33356.14
And this is the exact reason why fantasy builds are not allowed. Locked.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1279220-audio-pc/#findComment-14288345
Guest
