Ever since i upgraded my intel i5 9400f to the i7 9700k i had a problem where i cant hear from my monitors anymore, and then some usb devices do not work and i know this problem is coming straight from the motherboard, i upgraded bios and downgraded bios but no fix, i tried reinstalling drivers and still nothing, is there anything i can do to fix this to avoid having to buy a new motherboard? i got a b365m basooka from msi. could it be i plug it in and plug it out
https://linustechtips.com/topic/1279158-cpu-upgrade-issue/
Well b365 isn't really the "i7 do it all" - chipset but it should still work. Have you tried reinstalling windows as well?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1279158-cpu-upgrade-issue/#findComment-14287430
1 minute ago, s0uljaanthony said:
also when i first upgraded my cpu the motherboard loading screen froze and i had to update the bios for the cpu to work properly.
my fault its a b360m basooka motherboard.
https://linustechtips.com/topic/1279158-cpu-upgrade-issue/#findComment-14287489
Makes sense if the bios version didn't support the CPU. Have you checked on the motherboard page if it does actually support the cpu though?
And with the recovery media... It sounds like somethings messed up. I'd say make a backup (which ofc you should already have) and throw your complete windows installation away and start from scratch.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1279158-cpu-upgrade-issue/#findComment-14287503
it does support  and how do i start from scratch?
https://linustechtips.com/topic/1279158-cpu-upgrade-issue/#findComment-14287525
