So I just built a PC and started updating drivers on my MoBo. And I updated the driver that enabled optane memory. Intel recommended it then forced a restart. Now I have a DRAM failure and get a blank screen. I did enable XMP several reboots prior to this. Need help. DM me or anything so I can fix this. Thanks!
https://linustechtips.com/topic/1278709-optane-memory-causing-dram-issue/
Did you have the Optane stick installed? Easy solution will be to take that out and get rid of that driver.
Desktop benching:
im not sure with optane. i have never used optane before. if its not booting the best thing to do is reset the bios back to defaults and see if it boots then. if you do get into windows then check the drivers. but install the drivers the way i posted in this other thread. this avoids installing bad or wrong drivers.
hmm start from scratch. unplug everthing thats not needed. take out the cmos battery for one minute and put it back in. take out all the ram and only try to boot with one stick. to see if the mobo is working try to get a post with as little possible connected.
