Optiplex Help
Solved by WhitetailAni,
Core 2 Quad Q9300 (Q9650 was $50 USD on its own): $30 USD
4GB DDR3-1600 (I'm assuming you want 8GB): $14 USD
$6 USD left for a card... hmmm...
Well, Christmas is coming, and it has a VGA port. It likely has a GPU somewhere on the board.
My advice:
Get the CPU and RAM, and use the iGPU on the board until you have more to spend.
Plus, most GPUs are expensive right now.
Yes, even PCI ones.
