Storage Problem
Go to solution Solved by Aninda Muktadir,
I'm using a 600GB HDD as boot drive. I install games on this HDD.But I'm currently running out of space. I've another 1TB HDD. Can I install games on the 1TB drive(Non boot drive)? and will there be any performance issues ?
Just now, Aninda Muktadir said:
@Amias Both are same 7200RPM HDD connected via SATA 6GB/s
Oofff. Really?
A platter harddrive ... you're looking at about 80-160 MB/s.
An SSD through SATA, (pretty much any SSD) would give you 550 MB/s.
An NVMe drive, ... 2000MB/s+
https://linustechtips.com/topic/1277804-storage-problem/#findComment-14277155
@Amias But the games don't need that much read speed.
Sequential reed speed of Battlefield 1 is about 80-110MB/s
Urm.
Okay. Once you're loaded. The game will run just fine. However that loading ... takes forever ... without an SSD?
https://linustechtips.com/topic/1277804-storage-problem/#findComment-14277172
For game/program installs that don't need backups, i recommend RAID0
I put 6 drives in RAID0 and i get about 80% of the performance of SSDs for my particular use case. Not benchmarks, just general use.
I also only partitioned the first 80% of the volume to "short-stroke" it and get somewhat higher speeds.
I have also tried NVME drives and RAM drives but game loading times are not anywhere close to instant. I thought installing on a Samsung 970 NVME drive would make Witcher 3 load much faster but it's mostly about the same. So better to just use cheap drives in RAID0
https://linustechtips.com/topic/1277804-storage-problem/#findComment-14277181
