So I just bought a rog strix scope tkl deluxe edition(my first ever mechanical keyboard) and it's purely amazing, except it makes a little coil whine. Now the noise isn't really audible unless I intentionally put my ear next to the keyboard in order to hear it, but I just wanted to know if I should be worried about this.
https://linustechtips.com/topic/1277715-keyboard-noise/
I haven't had coil whine in my own mechanical keyboards, but I do know that it shouldn't directly affect the rest of the keyboard (actuation and build quality). If the coil whine becomes more annoying, then depending on the manufacturer or retailer you bought it from, you may be able to trade it in for a new one. But, if it's not bothering you, it should be fine.
https://linustechtips.com/topic/1277715-keyboard-noise/#findComment-14276855
That's normal, likely the power delivery for the LEDs. Does it go away if you turn the LEDs off?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1277715-keyboard-noise/#findComment-14276962
