Is a VDG Adapter compatible if I connect it to a Corsair Lighting Node Pro which uses Dupont Connectors??
Solved by thrasher_565,
8 hours ago, CJJubane said:I've been looking up something and I wanna try putting an aRGB fan inside my case. In my case I already have a Lighting Node Pro that I bought previously, I've seen videos that enables aRGB lightings from other brands that works with the Node Pro using a 3 pin to a Dupont Connector. I've been looking up on the internet on where to find it locally but I've noticed it's only on sale in the U.S. I found that the VDG Adapter looks similar to the Dupont connectors that corsair uses and it is widely available on my locality. I wonder if it is possible for it to work or not, I haven't done enough research though.
it will work it just wont lock in,
